Go Back   FedoraForum.org > Fedora Resources > Guides & Solutions (No Questions)
Guides & Solutions (No Questions) Post your guides here (No links to Blogs accepted). You can also append your comments/questions to a guide, but don't start a new thread to ask a question. Use another forum for that.
Old 21st August 2009, 07:47 AM
Jeff72 Offline
ATI Catalyst 9.x fglrx driver manual install on Fedora 11
UPDATE 8/28/2009: I now recommend that people install the new packages instead of the manual instructions below, see this link:
http://forums.fedoraforum.org/showthread.php?t=155503 (Howto for fglrx/catalyst (Ati driver) and Compiz-fusion)
NOTE: After installing the packages, I had to do the things at the following link to make the above packages work:
http://forums.fedoraforum.org/showpo...postcount=3564
If you still want to install the driver manually (you do not need to if you install the packages above), the instructions are below:
Fedora 11 ATI fglrx driver manual install notes
Updated: 10/12/2009
First, see if your graphics card is supported by the ATI Catalyst 9.8 driver by reading the PDF release notes here: https://a248.e.akamai.net/f/674/9206...t_98_linux.pdf
IMPORTANT: The manual method applies to your active kernel. So if you later update your kernel you will need to recompile the fglrx.ko module and initrd or uninstall then reinstall the fglrx driver package. See NOTES section below.
My experience with the ATI fglrx driver was on this:
Fedora 11 32-bit
ATI 4850 graphics card
# Run all of the following commands as the "root" userID
# update your system
yum update
# reboot to boot on any new kernel installed
init 6
# backup old /etc/X11/xorg.conf file, if there is one:
cd /etc/X11
mv xorg.conf xorg.conf-old
# Get and install fglrx driver (this compiles the fglrx kernel module for your active kernel)
# Get Catalyst 9.8 driver for Linux here: http://ati.amd.com/support/driver.html
# Put "ati-driver-installer-9-8-x86.x86_64.run" Catalyst 9.8 driver file in /tmp/ati and run it to install driver
# NOTE: the driver install is a graphical install
mkdir /tmp/ati
cp /path/to/ati-driver-installer-9-8-x86.x86_64.run /tmp/ati
cd /tmp/ati
sh ./ati-driver-installer-9-8-x86.x86_64.run
# Run the following as root
aticonfig --set-pcs-str="DDX,EnableRandR12,FALSE"
REMOVE the following line from from your /etx/X11/xorg.conf file, if it is there:
Option "SWCursor" "true"
# Add the following lines to the /etc/modprobe.d/blacklist.conf file:
blacklist radeon
blacklist radeonhd
# Backup old initrd and remake initrd
cd /boot
mv initrd-`uname -r`.img initrd-`uname -r`.img-original
mkinitrd -v /boot/initrd-`uname -r`.img `uname -r`
# Reboot to activate new ATI fglrx driver
init 6
# To fix selinux issue with aticonfig, run the following line as "root" userID:
chcon -t textrel_shlib_t '/usr/lib/libatiadlxx.so'
# To change your resolution using ATI Catalyst Control Center, run this as the "root" userID:
amdcccle
NOTES:
# IMPORTANT: When you later update your kernel, you will need to uninstall fglrx and then reinstall fglrx for the new kernel.
# Note, you can probably just recompile the fglrx.ko module instead of uninstall and reinstall, but I will have to test this with the next kernel update:
# Example:
cd /lib/modules/fglrx/build_mod
./make.sh
cd /boot
mv initrd-`uname -r`.img initrd-`uname -r`.img-oldfglrx
# To UNINSTALL the fglrx driver, run the following as root:
cd /usr/share/ati
sh ./fglrx-uninstall.sh
# remove following 2 lines from /etc/modprobe.d/blacklist.conf file:
blacklist radeon
blacklist radeonhd
# revert to original initrd
cd /boot
mv initrd-`uname -r`.img-original initrd-`uname -r`.img
# or, if you don't have your original initrd, just remake it:
mv initrd-`uname -r`.img initrd-`uname -r`.img-fglrx
# Re-install original mesa-libGL library:
yum reinstall mesa-libGL
# aticonfig command options:
# help:
aticonfig -h
# generate initial basic ATI /etc/X11/xorg.conf file
aticonfig --initial
# temperature:
aticonfig --od-gettemperature
# clocks:
aticonfig --od-getclocks
# fanspeed:
aticonfig --pplib-cmd "get fanspeed 0"
# To see fglrx info:
fglrxinfo
# Useful Referenced Links:
Howto for fglrx (Ati driver) and Compiz-fusion: http://forums.fedoraforum.org/showthread.php?t=155503
ATI Adapters xorg.conf specifications: http://www.x.org/archive/X11R6.8.0/doc/ati5.html
fglrx man page: http://debian.wgdd.de/temp/fglrx_man/fglrx.4x.html
fglrx wiki: http://en.wikipedia.org/wiki/Fglrx
Phoronix AMD/ATI Linux forum: http://www.phoronix.com/forums/forumdisplay.php?f=19
Old 21st August 2009, 09:18 AM
blueskynis's Avatar
blueskynis Offline
Thanks for your post. I'm confused why do you use ATI 64 bit for installation on 32 bit system. Is that a typo error?
Old 21st August 2009, 03:47 PM
joe.pelayo's Avatar
joe.pelayo Offline
An ape descendant
macosfirefox
He didn't make any 'typo error'. That apparent confusion comes from the fact that ATI releases both drivers (32/64) in the same file.
BTW, to the OP, thanks for the guide. Tonight I'll try it in 64bit Fedora 11.
Thanks,
Joe.
Notebook: Acer Aspire 5536-5112.
AMD Athlon X2 QL64 @ 2.1GHz, 4GB DDR2 PC2-5300, ATI Radeon HD3200 (256MB), 250GB Toshiba HDD, HL-DT-ST DVDRAM GT20N
Fedora 16 x86_64
Netbook: Acer Aspire One A150
Intel Atom N270 @ 1.6GHz, 1.5 GB DDR2 PC2-4200, Intel Graphics (8MB?), 160GB Seagate HDD
Fedora 15 i686
Old 21st August 2009, 04:35 PM
blueskynis's Avatar
blueskynis Offline
OK, thanks for clearing that up.
Old 21st August 2009, 06:19 PM
Replicant10000 Offline
I thought it didn't work with the newest xserver?
Oh well, I'll try that later.
Old 21st August 2009, 08:29 PM
Hlingler's Avatar
Hlingler Offline
linuxopera
Thread "stickied" after consult with OP.
Thanks Jeff72,
V
Old 21st August 2009, 09:16 PM
Parakro Offline
Thanks for posting this guide.
Old 21st August 2009, 09:35 PM
olson Offline
windows_98_nt_2000safari
Is RPM Fusion no longer maintaining the kmod-fglrx packages for AMD/ATI video drivers? In the past I'd used those for video drivers but I don't see them in the repository for Fedora 11. Seeing this manual install guide confuses me because everyone always says manually installing the video drivers overwrites many system files that can't be repaired even if the driver is removed. Am I missing something?
Old 21st August 2009, 09:40 PM
Hlingler's Avatar
Hlingler Offline
linuxopera
Yes, they are - but up until a day or two ago, there simply was no such driver (that worked on F11) to maintain. Give them a few more days to get some RPMs built.....
Correct: https://fedoraproject.org/wiki/Xorg/..._Video_Drivers
But as of today, there is only one option: binary installer. Better than nothing? As long as you know the possible consequences.... And the "damage" can (usually) be repaired, if necessary.
HTH,
V
Old 21st August 2009, 09:48 PM
olson Offline
Great information! I'll probably hold out for another week and see if RPM Fusion has the new drivers packaged and go from there. I just switched from Ubuntu back to Fedora and wasn't up to speed with the situation. Thanks!
Old 22nd August 2009, 12:02 AM
Hlingler's Avatar
Hlingler Offline
linuxopera
I really don't mean to hammer on the binary drivers (which usually work well), but here's yet another example of what can happen with such binary "blobs": http://forums.fedoraforum.org/showth...60#post1256860
Note that, as the posts before that point out, the vast majority of "casual" users will never notice any problems - unless and until they do something that exposes such issues (like: switch driver/hardware, try to compile stuff that needs libGL*, & etc.).
Just so you know....
V
Old 22nd August 2009, 12:07 AM
olson Offline
V
I've used the binary drivers for nVidia a few times and if I remember right they break when the kernel gets updated, which is pretty often if letting the system update. Not sure if AMD/ATI drivers are the same in that sense. Thanks again for the info!
Old 22nd August 2009, 12:54 AM
Hlingler's Avatar
Hlingler Offline
linuxopera
Might as well point out here for the record:
Yes, the binary driver "blob" must be re-installed after a kernel (or Xorg, Mesa, or libdrm) update, for no other reason than it has to re-build your new kmod.
Yes, that's fairly often with Fedora.
Yes, any binary video driver package using kmods (NVidia, ATI) is the same in that respect.
V
Nope, OP's first idea doesn't work with the ATI drivers for my card (X1200.)
I get:
which: no XFree86 in (/usr/lib64/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/bin:/usr/local/sbin:/usr/sbin:/usr/bin:/sbin:bin)
Error: ./default_policy.sh does not support version. default:v2:x86_64:lib::none:2.6.30.5-32.fc11.x86_64:make sure that the version is being correctly set by --iscurrentdistro
Is there anything else I can try?
Old 22nd August 2009, 01:32 AM
olson Offline
I get:
The latest Catalyst release that this post talks about doesn't support that chipset anyway (probably not why you get the error though). Warning, its a PDF link.
Only Radeon X3000 or newer is supported in the binary drivers from now on. I think Catalyst 9.3 was the last to support that chipset but it might be newer than that if the release notes say so. Cheers!
ati, catalyst, driver, fedora, fglrx, install, manual
Howto for fglrx / catalyst (Ati driver) leigh123linux Guides & Solutions (No Questions) 4813 Yesterday 12:03 AM
How to install ATI Catalyst 9.6 in Fedora 11 (as of Jun 20th) aaccdd Guides & Solutions (No Questions) 25 12th July 2009 03:14 PM
ATi FGLRX Driver 86_64 Install Help psychobot Hardware & Laptops 9 4th February 2009 12:31 PM
[Fedora 10] Black Screen After Catalyst install Iska Hardware & Laptops 1 11th January 2009 06:04 PM
Cannot install ATI-propetiary driver in FC2 (fglrx) iskake Hardware & Laptops 2 12th November 2004 03:55 PM
Current GMT-time: 10:28 (Tuesday, 21-05-2013)
