Go Back   FedoraForum.org > Community Lounge > Fedora Focus
Fedora Focus Come in and have a general chat about Fedora and things relating to Fedora.
Old 17th December 2009, 11:44 PM
AdamW's Avatar
AdamW Offline
Fedora QA Community Monkey
Testing request: latest F12 xorg-x11-server build
Hi, everyone. Dave Airlie would like it if people could help us
regression-test the latest xorg-x11-server build for F12, which you'll
be able to find here:
http://koji.fedoraproject.org/koji/b...buildID=147423
We have quite a lot of changes queued up, and we will need to send these changes out as an update at some point - there's important fixes in there. But we'd like some reasonable assurance that it doesn't break anything horribly, obviously. If those of you with F12 machines could stick this build on and make sure things work alright, that'd be great.
Please report whether it seems OK or you run into problems in this thread. Thanks!
Adam Williamson | awilliam AT redhat DOT com
IRC: adamw | Twitter: AdamW_Fedora | identi.ca: adamwfedora
http://www.happyassassin.net
Old 18th December 2009, 12:09 AM
dd_wizard's Avatar
dd_wizard Offline
Works For Me
[gene@Mobile-PC ~]$ yum list installed xorg-x11-server*
Loaded plugins: fastestmirror, presto, refresh-packagekit, remove-with-leaves, show-leaves
flash        1/1
Installed Packages
xorg-x11-server-Xorg.x86_64       1.7.3-3.fc12      @/xorg-x11-server-Xorg-1.7.3-3.fc12.x86_64
xorg-x11-server-common.x86_64     1.7.3-3.fc12      @/xorg-x11-server-common-1.7.3-3.fc12.x86_64
Running a terminal window, log file viewer, firefox, and exaile at the moment, and all is well. Log file:
X.Org X Server 1.7.3
Release Date: 2009-12-3
X Protocol Version 11, Revision 0
Build Operating System: x86-7 2.6.18-164.6.1.el5
Current Operating System: Linux Mobile-PC 2.6.31.6-166.fc12.x86_64 #1 SMP Wed Dec 9 10:46:22 EST 2009 x86_64
Kernel command line: ro root=/dev/mapper/vg_mobilepc-lv_root  LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=us
Build Date: 17 December 2009  12:08:29AM
Build ID: xorg-x11-server 1.7.3-3.fc12
looks clean, too.
EDIT: Gnome/Openbox on a Toshiba laptop, Smolt ID.
dd_wizard
Old 18th December 2009, 01:29 AM
SlowJet Offline
I is working ok on My F12 and 1/2 systems.
Pent IV intel865BGF intel graphics Gnome
Pent II VIA Apollo-133 Nviidia NV11 using nouveau drv Gnome servers(httpd, mysql, samba, subversion)
SJ
Do the Math
Old 18th December 2009, 03:11 AM
David Batson Offline
linuxopera
Pardon my ignorance - or not...
I was considering trying it, but I do not see this package in updates-testing but instead an older xorg-x11-server-Xorg-1.7.1.9.fc12.i686 - updates-testing package. It appears to me that this is on the koji repository, but I haven't figured out how to add that repository. Why would it not be in updates-testing?
Fedora 18 Gnome on a ThinkPad X220, i5-2540M CPU, Intel HD Graphics 3000, Intel N 6205 wireless, and Sierra Wireless 754S Mobile Hotspot (AT&T)
Old 18th December 2009, 03:23 AM
SlowJet Offline
You download the rpm's and install/update with rpm program.
The point of the test is to verify it does NOT trash anything BEFORE it gets to updates-testing.
An extra Quality Assurance from AdamW, the QA engineer for redhat.
SJ
Do the Math
Old 18th December 2009, 03:25 AM
Demz
Guest
Posts: n/a
windows_7firefox
http://koji.fedoraproject.org/koji/b...buildID=147423 use rpm --Uvh to get it from koji
Old 18th December 2009, 03:46 AM
aleph's Avatar
aleph Offline
Banned (for/from) behaving just like everybody else!
Seems to be working well enough for me
I believe in nerditarianism. I read FedoraForum for the Fedora-related posts.
Old 18th December 2009, 04:49 AM
linuxopera
Originally Posted by Demz View Post
I saw the link already, but rpm -Uvh won't automatically download from koji will it? I wouldn't think so.
I understand how to download the set of files and install locally. I just thought it would be easier from a repository.
dd_wizard wrote: [gene@Mobile-PC ~]$ yum list installed xorg-x11-server*
This made me think he was installing from a repository.
Old 18th December 2009, 08:08 AM
Demz
Guest
Posts: n/a
windows_7firefox
this is why Adamw posted the URL to download X-Server . rpm -Uvh followed by the URL link should install the appropriate stuff
Old 18th December 2009, 08:38 AM
PavanKY's Avatar
PavanKY Offline
I would like to test it, but could anyone tell me the files that I might need to back up ?
Also, does installing the following package take care of everything that is needed?
xorg-x11-server-source-1.7.3-3.fc12.noarch.rpm
or do I need to install xorg-x11-server-*.rpm ?
"If it is not broken, try harder"
Old 18th December 2009, 06:30 PM
AdamW's Avatar
AdamW Offline
Few notes: if you want a 'backup', just keep a copy of the current official packages handy. The worse that can happen with this update is X stops working, in which case you just boot to a console and install the old packages with rpm.
You need to update any of the packages that are available from the koji page which you currently have installed - usually xorg-x11-server-Xorg, xorg-x11-server-common, and possibly xorg-x11-server-devel - to the 1.7.3-3 version, to do a proper test.
the reason this isn't in updates-testing is we just wanted a sanity check before even putting them in there, since X.org is a sensitive component.
Old 18th December 2009, 06:56 PM
dd_wizard's Avatar
dd_wizard Offline
David, I downloaded the xorg-x11-server-Xorg and xorg-x11-server-common RPMs from koji, then did
sudo yum --nogpgcheck localupdate xorg*
in the download directory. That way, yum knows about the update, and it can be undone with yum if things break. Of course, koji packages never break anything, but it's still a good idea.
dd_wizard
Old 19th December 2009, 12:24 AM
linuxopera
Didn't work here. Just tried it to see if it would. I could have the syntax wrong...
[root@localhost ~]# rpm --Uvh xorg-x11-server* http://koji.fedoraproject.org/koji/buildinfo?buildID=147423
--Uvh: unknown option
You have mail in /var/spool/mail/root
[root@localhost ~]# rpm -Uvh xorg-x11-server* http://koji.fedoraproject.org/koji/buildinfo?buildID=147423
error: File not found by glob: xorg-x11-server*
Retrieving http://koji.fedoraproject.org/koji/buildinfo?buildID=147423
[root@localhost ~]#
BTW, AdamW could have posted the link so one could manually download the files as dd_wizard did. I just installed as per dd_wizard's instructions. After rebooting I still have a Gnome desktop. I take that as a good sign!
Old 19th December 2009, 06:57 AM
PavanKY's Avatar
PavanKY Offline
I was able to install them using this method mentioned by dd_wizard
Unfortunately these did not work on my system. I was able to log in, but once I logged in there was a small popup window which kept flickering (with no visible text), and I could see the desktop background.
That is when I jumped to console mode and did this
sudo yum downgrade xorg-x11-server-*
But before I did that I stored Xorg.*.log from /var/log. There were three files, I am not sure which ones would be relevant. The files being
1) Xorg.0.log
2) Xorg.0.log.old
3) Xorg.9.log
Please let me know which file you think would be relevant. I have a HP DV6000Z (AMD Turion X2, nvidia geforce 7200) running GNOME.
I would love to help further with whatever limited knowledge I have
Let me know what else I can do regarding this.
Old 19th December 2009, 06:31 PM
dd_wizard's Avatar
dd_wizard Offline
@silentfreak:
The current Xorg.0.log will tell you if any errors occurred the last time the X server started.
dd_wizard
Testing The New Hotness: kernel, metacity and xorg-x11-server updates AdamW Fedora 12 Alpha, Beta & Release Candidates 31 10th November 2009 06:54 PM
How to build latest n greatest Apache,PHP, OpenSSL rpms? bubudiu Servers & Networking 1 13th April 2005 07:14 PM
Current GMT-time: 19:43 (Tuesday, 21-05-2013)
