Old 1st February 2010, 04:05 PM
Redheart Offline
windows_xp_2003firefox
Old Panasonic CD changer drivers?
I'm in the process of switching to Linux... and among the drives I'm using is an older Panasonic SQ-TC512n 5 cd changer. It's still in very good shape, and I would like to continue using it.
Using it under Wxp has been a problem... I can, but sometimes it locks up XP because XP doesn't recognize that you can change CDs without opening the caddy (or at least, it doesn't on this computer). The only drivers I've found for the thing are DOS/W95 drivers, and as I remember, the W95 driver crashes under XP.
Is there a good driver under Linux for this thing? Maybe something that lets me switch disks automatically or something like that, or that recognizes that it is a changer?
I don't have the money to go out and buy new stuff, and I have good reason to want to have this changer operational (I have multiple CD's that I access regularly and it's a bother to be changing them out all the time- reference material CD's).
Any info on Linux usage of this device would be appreciated!
Bob
Old 1st February 2010, 04:41 PM
kyryder
Guest
Posts: n/a
I don't know the answer to your question, but I would recommend that you try booting the live cd and see if your cd changer works from the live cd as that will give you a idea of what to expect.
Hope this helps,
Ky
changer, drivers, panasonic
wp_tray or other wallpaper changer app. snookerzysta Using Fedora 1 23rd December 2009 02:18 PM
looking for a voice changer for fedora 7 kathera Fedora Focus 0 31st July 2007 12:05 AM
is there any automatic wallpaper changer for fc3? shams Using Fedora 12 17th August 2006 11:54 AM
wallpaper changer shaobohou Using Fedora 0 26th October 2005 10:17 PM
Current GMT-time: 03:21 (Friday, 24-05-2013)
