Go Back   FedoraForum.org > Fedora Resources > Guides & Solutions (No Questions)
Guides & Solutions (No Questions) Post your guides here (No links to Blogs accepted). You can also append your comments/questions to a guide, but don't start a new thread to ask a question. Use another forum for that.
Closed Thread
Old 1st November 2004, 11:05 AM
imdeemvp's Avatar
imdeemvp Offline
How to use YUM to install and uninstall packages
Introduction
To update the system applying the most recent corrective patches of security and to the operating system is not as difficult as many do not suppose, nor either must be a hell of dependencies between packages RPM as some others argue. The reality of the things is that it is much very simple and single requires of good bandwidth or very many patience. Next we presented/displayed the procedures to use yum and to make easily what some denominate "horrible, difficult and complicated ".
Please note there are some changes that apply to Fedora Core 3. You will need to install GPG Key for yum in FC3.
Creating Yum Repo's For FC3.
To update system. Update of the system with all the dependencies that are necessary:
yum update
Searches. To make a search of some package or term in the data base in some of the formed deposits yum in the system:
 yum search any-package
Example:
yum search httpd
I hope this will help you understand how to use yum more effeciently. Any erros in this how please notify me.
Consultation of information. To consult the information contained in a package in individual:
 yum info any-package
Example:
yum info httpd
Installation of packages. Installation of paquetería with automatic resolution of dependencies:
 yum install any-package
Example.
yum install gkrellm
Uninstalling packages. Desinstalación of packages along with everything what it depends on these:
yum remove any-package
Example.
yum remove gkrellm
Listing Packages. The following thing will list all the packages available in the data base yum and that can settle:
 available yum list|less
The following thing will list all the packages installed in the system:
 yum list installed|less
The following thing will list all the packages installed in the system and that can (they must) be updated:
 yum list updates|less
Cleaning of the system.
Yum leaves as result of its use heads and packages RPM stored in the interior of the directory located in the route /var/cache/yum/. Particularly the packages RPM that have settled can occupy much space and is by such reason agrees to eliminate them once no longer they have utility. Also it agrees to do the same with the old heads of packages that no longer are in the data base. In order to make the corresponding cleaning, the following thing can be executed:
 yum clean all
Group install
yum groupinstall "groupname"
Dont forget the quotation marks for group install.
I hope this will help you understand how to use yum more effeciently. I did this for our newbies that may want to uninstall packages which is not mention in the fedora FAQ. For more info on yum go here: http://www.fedorafaq.org/#installsoftware
HELP with JAVA, MP3's, Wireless, Repo's, YUM, Partitions, System Monitors, Nvidia, ATI drivers, LIMEWIRE PRO & MORE!.
Easiest and most friendly desktop ever is PCLinuxOS! Includes all this apps. Just try it.
"The greater the struggle THE greater the achievment."
Do you know HIM?
If you are an idiot click here. NThis will test you linux skills :D
Old 1st November 2004, 11:16 AM
ilja Offline
Great howto.
One tip, you can use also joker-signs as * or ? e.g.
yum install gkrellm*
will install gkrellm, gkrellm-plugins, gkrellm-misc-plugins etc.
And to install/remove you have to be root! Not for searching.
http://twitter.com/ik12
Old 1st November 2004, 11:43 AM
imdeemvp's Avatar
imdeemvp Offline
Thanks for the tip.
Do you know HIM?
Old 1st November 2004, 02:02 PM
foolish's Avatar
foolish Offline
Retired Community Manager
Here's more:
To search in package names only, use yum list. This differs from search in that it's much faster, as it will search package names only, while yum search will search all the package info, including package description.
yum list something
Example
yum list mozilla
To get the name of the package containing a given file:
yum provides filename
example:
yum provides /usr/bin/mozilla
Here's some new goodies in yum 2.2 (Fedora Core 3 and beyond)
To get a list of packages updated/added to any of your repositories recently:
yum list recent
To enable a repository which is disabled in the configuration:
yum --enablerepo=reponame install packagename
example
yum --enablerepo=dag install j2re
To list available software groups, such as GNOME desktop environment or X window system. This is also available in the Core 2 yum, but servers doesn't use this wonderful feature much.
yum grouplist
To install such a group:
Example:
yum groupinstall "GNOME Desktop Environment"
And to update a group
yum groupupdate "GNOME Desktop Environment"
And remember folks, you can always use -y to say yes to everything, and -C to use the cache only.
Sindre Pedersen Bjørdal || http://www.fedorasolved.org || Hardware Profile
- Please adhere to the FedoraForum Guidelines.
Old 2nd November 2004, 08:40 AM
imdeemvp's Avatar
imdeemvp Offline
Thanks again for the add-ons.
Do you know HIM?
Old 2nd November 2004, 09:19 AM
sayeeth's Avatar
sayeeth Offline
YUM is a delicious treat indeed. I never knew it had so much to it. Thanks imdeemvp and foolish!
[sayeeth@somebody ~]$ kill bill
bash: kill: bill: arguments must be process or job IDs
Old 8th November 2004, 05:06 PM
tashirosgt Offline
Whoever gave that recommendation to the effect that "here are the only three repositories that yout need to get all the good add-ons", please repeat it here. I didn't find it by searching the forum messages.
"Never let the task you are trying to accomplish distract you from the study of computers."
Old 9th November 2004, 05:48 AM
ewinandar Offline
Thanx for the kind to share this information :-)
regards,
newbie
Old 13th November 2004, 03:50 AM
ewinandar Offline
got problem using yum
Dear All,
since i'm a newbie :-)
I've got problem when using yum command.
The error seems because of need to connect to www.redhat.fedora.
is it suppoused to connect?
Old 13th November 2004, 09:12 AM
imdeemvp's Avatar
imdeemvp Offline
ewinandar, to do your updates you need to have an internet connection...do you?
Do you know HIM?
Old 14th November 2004, 10:32 PM
loninappleton Offline
why do my yum requests always hang?
I have tried to yum specific files repeatedly and the progress bar just hangs: no error shown with things
like 1 sec ETA.
Distro is Fedora Core2
What is going on with this?
thanks
lon@athenet.net
Old 14th November 2004, 11:07 PM
imdeemvp's Avatar
imdeemvp Offline
It happens to everyone not just use. I get that a lot and I have a dsl connection. If i see stay there for more then 10 mins. than I close terminal and restart yum update or whatever.
Do you know HIM?
Old 17th November 2004, 02:43 AM
ewinandar Offline
So i have to connect to internet in order to be able to use yum.
Thanx for the info.
Old 17th November 2004, 09:52 AM
imdeemvp's Avatar
imdeemvp Offline
Yes, you have to be connected to keep your system up to date.
Do you know HIM?
  #15
Old 17th November 2004, 02:56 PM
Tru Offline
Hey imdeemvp and loniappleton, I also had same problem in fc2, but now in fc3 with the way they have yum working it is much faster and it rarley if ever hangs it is very nice I remeber with fc2 usally it always hung on the first try.
Closed Thread
install, packages, uninstall, yum
How do I uninstall after a bad install ? OralDeckard Using Fedora 0 24th June 2009 01:22 PM
cant install/uninstall anything nightsight Using Fedora 4 2nd May 2009 09:31 PM
Uninstall or remove the packages without the related ones emremulazim Installation and Live Media 0 30th March 2006 07:23 AM
Uninstall Individual Packages azumbrunnen Using Fedora 3 10th September 2005 09:30 AM
how uninstall packages don't existe in fedora CD's seif_root Using Fedora 3 4th September 2005 05:01 AM
Current GMT-time: 10:11 (Thursday, 23-05-2013)
