Go Back   FedoraForum.org > Fedora 17/18 > Installation and Live Media
Installation and Live Media Help with Installation & Live Media (Live CD, USB, DVD) problems.
Old 28th May 2011, 02:27 PM
gkasica Offline
windows_7chrome
FC15 preupgrade failue on java-1.5.0-gcj-javadoc-1.5.0.0-35.fc15.i686
In the process of running preupgrade for FC14 to FC15 here and am stuck with a fatal error at the point after Reboot where the packages are installing. There were 2703 to update at the start and its down to the last 400 or so. The error is in te screen shot below, but basically its saying it cannot install the package and to check the installation media.
I'm running the install from the hard disk and there is more than enough room for the files, nothing is full, ran a rescue CD to check the file systems for problems, etc. all looks good and I can read/write to the location where the file is stored.
One thing I DO notice is the screen shows a size of 235MB, yet looking on disk the file is showing 14,650,536 bytes for both the old and new versions. I've tried to replace the RPM with one from Fedora's FTP site but its also the same size as the original and gives the samer error.
How do I go about correcting this or bypassing the file so that the install can finish?
Right now I'm stuck with half a FC14 and half a FC15 server here and obviously that doesn't run very well.
Thanks,
George Kasica
Click image for larger version
Name:	FC15 error.jpg
===[George R. Kasica]=== +1 262 677 0766
georgek@netwrx1.com +1 206 374 6482 FAX
http://www.netwrx1.com/georgek Jackson, WI USA
georgek@netwrx1.com
ICQ #12862186
("`-''-/").___..--''"`-._
`6_ 6 ) `-. ( ).`-.__.`)
(_Y_.)' ._ ) `._ `. ``-..-'
_..`--'_..-_/ /--'_.' ,'
(il),-'' (li),' ((!.-'
Old 29th May 2011, 12:18 PM
gkasica Offline
windows_7ie
Re: FC15 preupgrade failue on java-1.5.0-gcj-javadoc-1.5.0.0-35.fc15.i686
SOLVED!!
Got a hint from http://www.linuxquestions.org/questi...-on-fc9-686050
and looked in /usr/share/javadoc/java from the LIVE CD and found the only file there was a symbolic link back to itselfs for the FC-14 version. I removed the directory (including the symbolic link in in with
rm -rf /usr/share/javadoc/jave and rebooted to the Preupgrade installer mode and its now continuing as expected.
georgek@netwrx1.com
ICQ #12862186
preupgrade FC14->FC15: cannot download ks.cfg andyzhu35 Installation and Live Media 0 28th May 2011 12:16 PM
fc14 preupgrade to fc15 hang on first boot prague Installation and Live Media 3 28th May 2011 01:30 AM
BCM4313 not work in 2.6.38.6-27.fc15.i686.PAE ? amfpg Using Fedora 0 27th May 2011 10:29 PM
[SOLVED] FC15 Networking problem after preupgrade flashl F15 Development 0 23rd May 2011 04:56 PM
Server Not Started When Upgraded to 2.6.36-0.8.rc2.git0.fc15.i686.PAE danielch F16 Development 0 24th August 2010 06:52 PM
Current GMT-time: 21:04 (Friday, 24-05-2013)
