Old 16th December 2011, 08:29 AM
dalcocer Offline
F16 Crackling noise in captured audio
I cannot produce a clean audio capture using Fedora 16 on my desktop PC. The captured audio has a faint but very noticeable crackling to it. Opening the captured audio file in Audacity shows clicks and pops in the recording.
Before I give up and install Windows 7, I thought I'd check here first to see if anything can be done to fix this.
I've verified the following:
  • there's no problem with the input audio cable (the same cable produces clean recordings with my laptop, using the Windows XP port of Audacity)
  • checked that I'm using the line input, not the microphone input
  • checked line input is unamplified (Applications, System Setting, Sound, Input tab)
  • audio output works fine (tested using known-good MP3 audio files)
I've attached the captured audio (dtmf-recording.zip) and the source audio (dtmf-sample.zip); both are FLAC files. The audio I'm using for testing is a small 12-second sample of eight DTMF tones; this input makes it easier to hear the distortion present in the captured audio.
Hardware: Asus Crosshair IV Formula motherboard (8GB RAM), using AMD Phenom II X6 1090T CPU (3.7 GHz).
Output of "sudo arecord -l"
**** List of CAPTURE Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: VT2020 Analog [VT2020 Analog]
  Subdevices: 2/2
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
Output of "sudo aplay -l"
**** List of PLAYBACK Hardware Devices ****
  Subdevices: 1/1
card 0: SB [HDA ATI SB], device 1: VT2020 Digital [VT2020 Digital]
  Subdevices: 1/1
card 0: SB [HDA ATI SB], device 2: VT2020 HP [VT2020 HP]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
Output of "lspci -v | grep -A7 -i audio"
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) (rev 40)
	Subsystem: ASUSTeK Computer Inc. M4A89GTD PRO/USB3 Motherboard
	Flags: bus master, slow devsel, latency 64, IRQ 16
	Memory at fcbf8000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: <access denied>
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd-hda-intel
06:00.1 Audio device: nVidia Corporation HDMI Audio stub (rev a1)
	Subsystem: eVga.com. Corp. Device 1521
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Memory at fe97c000 (32-bit, non-prefetchable) [size=16K]
Any ideas on how to fix this, or additional troubleshooting steps I should perform, are welcome.
Old 16th December 2011, 05:56 PM
sonoran's Avatar
sonoran Offline
Re: F16 Crackling noise in captured audio
You've probably thought of this already, but make sure you mute your mic inputs.
Old 16th December 2011, 10:19 PM
Chilly Willy's Avatar
Chilly Willy Offline
Since you say you are using an MP3 file, I'll assume that you are using an MP3 player for your input. If so, did you check that the output of this is clean? (or whatever device you ARE using?)
Just for "S & G's" what does it do if you DO use a mic? - what does Audacity's waveform look like then?
You may want to try something with a LOW output in the MIC input (other than the MIC) to see it it may be your line-in that is causing this. - make sure it matches the input requirement as not to damage anything. (low input amplitude & proper impedance - apm. being more important, for this short duration test)
Chilly Willy, Tux's little cousin...
By its very nature, Windows is a PANE!
audio, captured, crackling, f16, noise
Audio, frying noise buczbucz Using Fedora 0 5th June 2011 11:23 AM
HDMI audio from monitor is crackling very loud AllWires Using Fedora 0 28th September 2010 02:26 PM
Crackling noise when switching songs cjnkns Using Fedora 2 19th March 2010 02:44 AM
constant crackling in audio ravalox Hardware & Laptops 2 5th November 2009 07:34 AM
chip noise in audio system carthur123 Using Fedora 1 15th August 2006 01:41 PM
Current GMT-time: 14:33 (Wednesday, 22-05-2013)
