Go Back   FedoraForum.org > Fedora 17/18 > Servers & Networking
Servers & Networking Discuss any Fedora server problems and Networking issues such as dhcp, IP numbers, wlan, modems, etc.
Old 24th February 2012, 03:07 AM
heigold1 Offline
windows_vistaie
Re: Accessing apache server remotely from another machine (newbie).
JPollard, yes when I do the "ifconfig -a" then i get "192.168.0.255" for the "wlan0" entry.
So that's probably what it is then?
Old 24th February 2012, 11:15 AM
Jake Jast's Avatar
Jake Jast Offline
Do you know how a router works? Every computer connected to it (both with cable, both with wireless) has a private ip address that must be 192.168.1.x where "x" is a number >1 <255 . The address 192.168.1.1 is the one of the router. If you type this ip(192.168.1.1) on your browser will appears the router's configuration page. If you want to see what is your private ip, you have to run "ifconfig -a". This command display all your internet connections. The output must be a thing like that:
eth0      Link encap:Ethernet  HWaddr 00:25:22:B9:72:88
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::225:22ff:feb9:7288/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:6212 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5834 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3947652 (3.7 MiB)  TX bytes:1026119 (1002.0 KiB)
          Interrupt:44 Base address:0xc000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:960 (960.0 b)  TX bytes:960 (960.0 b)
wlan0     Link encap:Ethernet  HWaddr 00:26:5A:6D:43:92
         inet addr: 192.168.1.194  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::226:5aff:fe6d:4392/64 Scope:Link
          RX packets:79 errors:0 dropped:0 overruns:0 frame:0
          TX packets:77 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:8383 (8.1 KiB)  TX bytes:17689 (17.2 KiB)
Do you see where is red and bold? This is my wireless private ip. If you connect to your private ip you will see the same if you go to "127.0.0.1".
Now, I think that JPollard wanted to say you that you must do a "port mapping". This lets the router to redirect anyone that connects to your public ip(the one that you see at "whatismyipaddress.com") at the private address(192.168.1.x) of your pc.
Well, I can't explain you how do a port mapping because surely you haven't my same router. But I can say that you must tell to your router(from 192.168.1.1) that if someone connects to your public ip with the 80/tcp port(the one of apache and all other http servers in this world; anyone that connect to an http server use this port), it must redirect the request to your pc private address. For do that see the manual of your router.
Old 25th February 2012, 01:15 AM
heigold1 Offline
windows_vistaie
Jake, when I go to http://192.168.1.1 i just a gateway timeout.
Any suggestions?
Also kttam how do you stop iptables and disable selinux?
Old 25th February 2012, 03:30 PM
Jake Jast's Avatar
Jake Jast Offline
windows_7firefox
oh, well your private ip is 192.168.0.255 so you can try 192.168.0.1 or at least 192.168.0.0
This depends by your router subnet mask
accessing, apache, machine, newbie, remotely, server
Accessing apache server remotely from another machine (newbie). heigold1 Servers & Networking 1 23rd February 2012 09:02 AM
Trouble accessing VNC Server remotely. chrisn8cuh Using Fedora 2 22nd August 2008 03:51 AM
Printing, and Accessing X remotely vkapila Using Fedora 6 4th March 2005 02:59 AM
Accessing FC2 server from XP machine Duke Henry Servers & Networking 10 25th July 2004 09:46 AM
Current GMT-time: 18:45 (Thursday, 23-05-2013)
