Old 10th May 2012, 07:30 PM
pligdas Offline
How to automount non-Fedora partitions with permissions
I have a Fedora 16/openSUSE system and I would like to be able to see all Linux partitions from Fedora, but with different permissions each partition. So far, I have edited the /etc/fstab
# /etc/fstab
# Created by anaconda on Mon May  7 13:55:42 2012
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
UUID=f1b581c4-6b29-4b86-8ad7-d4f152312e3a /                       ext4    defaults        1 1
UUID=c155e845-4fff-4b65-b5e1-710ee7e810a1 /home                   ext4    defaults        1 2
UUID=9caf39a4-f482-486a-9e75-56788b5e04d5 swap                    swap    defaults        0 0
UUID=adb4b6bf-60cc-48f4-8ff4-b1eda526c703 /FoS                    ext4    defaults        0 0
[pascal@pascaLinux ~]$
The point /FoS refers to a partition that has me as the owner (pascal instead of root), a small partition that I can read/write from both systems. This is fine for that particular partition but not for the following two, i.e. / and /home of openSUSE I would like to add.
How do I proceed from here? And what do the numbers 1 1, 1 2, and 0 ,0 refer to?
Thanks in advance,
- Pascal
---------- Post added at 09:30 PM ---------- Previous post was at 09:29 PM ----------
Sorry about my haste. I found my answer in http://www.tuxfiles.org/linuxhelp/fstab.html. [SOLVED]
I still have one question : why does my /etc/fstab file has lines like this
instead of
/dev/sda4        /FoS                    ext4    defaults        0 0
I understand how to use the command blkid, but is it really necessary?
- Pascal
Old 10th May 2012, 07:35 PM
DBelton's Avatar
DBelton Offline
Re: How to automount non-Fedora partitions with permissions
It is better to use the UUID= or LABEL= method or referring to your partitions instead of the /dev/sdXx method.
It is possible that your devices may not be named the same every time you boot your machine, but the UUID and LABEL stays the same.
Old 10th May 2012, 07:42 PM
pligdas Offline
Thanks for the clarification.
- Pascal
automount, nonfedora, partitions, permissions
Automount of additional partitions jeffpeterson Hardware & Laptops 1 19th November 2007 04:45 AM
automount other partitions Fittersman Hardware & Laptops 9 22nd August 2007 12:20 PM
Automount partitions? wvanooij Using Fedora 2 20th August 2007 02:49 AM
Fedora 7 : Automount and NTFS permissions schotty Using Fedora 1 2nd June 2007 12:37 PM
Can't automount ext3 partitions? txcrittr Using Fedora 0 21st January 2006 07:48 AM
Current GMT-time: 05:26 (Sunday, 26-05-2013)
