Old 8th June 2012, 05:23 AM
rurikc Offline
PulseAudio: Card not detected for all but one user
I have a F16 install with two users.
Une user sees the "internal audio analog stereo" in pavucontrol and can play sounds.
The other user and root see only the Dummy device and there is no playback (i.e. there is but on the Dumy device).
I am currently puzzled
Any suggestions appreciated.
Cheers.
Old 12th June 2012, 06:29 AM
rurikc Offline
Re: PulseAudio: Card not detected for all but one user
Continuing ...
It seems that only one user may control one audio device at a time ...
So, how can I enable other (local) users to connect to my (local) pulse audio server ?
I see a ~/.pulse-cookie but how do I use it ?
Cheers.
Old 12th June 2012, 02:56 PM
secipolla Offline
If you mean that you want both to use pulseaudio at once, maybe this Google search ( https://encrypted.google.com/search?...l=&gs_l=&pbx=1 ) helps?
(not saying that you don't now how to search, but just in case)
Old 12th June 2012, 11:19 PM
rurikc Offline
Thanks for the reply.
Interestingly I thought about searching for multiple users but not for two ... what do you know
Anyway I came across this solution that so far works for me:
Main user
Copy
/etc/pulse/default.pa
to
~/.pulse/default.pa
Add:
load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1
Second User
Create
~/.pulse/client.conf
and add
default-server = 127.0.0.1
With this configuration, when the second user launches an application that uses pulseaudio, it will connect to the main user's pulseaudio instance.
Reference: http://forums.fedoraforum.org/showthread.php?t=190954
card, detected, pulseaudio, user
Removed pulseaudio, no soundcard detected now! dataghost Hardware & Laptops 5 27th December 2010 03:09 PM
[Fedora 9 - No sound] Detla 44 not detected by pulseaudio Zeppe|in Hardware & Laptops 9 19th August 2008 12:01 PM
pulseaudio won't start as normal user a thing Using Fedora 1 28th July 2008 05:08 AM
displaying detected USB devices like an SD card reader and card KB1LQC Hardware & Laptops 1 27th June 2008 07:01 AM
ipw2200 wireless card detected as ethernet card tmort Hardware & Laptops 49 17th January 2007 11:00 PM
Current GMT-time: 06:29 (Thursday, 20-06-2013)
