Old 23rd May 2005, 04:59 AM
wangfeng Offline
Error:visibility arg must be one of "default", "hidden", "protected" or "internal"
when i rebuild rpm in amd 64.
this error comes out in some kde packets:
In file included from keduvocdata.cpp:19:
keduvocdata.h:41: error: visibility arg must be one of "default", "hidden", "protected" or "internal"
keduvocdata.h:49: error: visibility arg must be one of "default", "hidden", "protected" or "internal"
i look at the .h ,find just a class definition in line 41 and another in line49.
how to solve the froblem? and is the class definition different in 32 and 64? what's the difference between programming in 32 and 64?
arg, default, errorvisibility, hidden, internal, protected
"ls" and "cd" treat ".." differently inside symlinked directories bnorman Using Fedora 0 19th June 2008 04:49 PM
HOW TO MOUNT "C" "D" "E" LOCAL HARDDISK PARTITION ketan_hk Using Fedora 6 6th September 2007 01:10 AM
Metacity and "Xlib: extension "SHAPE" missing on display ":0.0". debu_sagii Using Fedora 0 29th August 2007 05:53 PM
error message say; Xlib: extension "XFree86-DRI" missing on display ":0.0". sturmkim Using Fedora 3 1st October 2006 04:40 AM
error: Xlib: extension "XFree86-DRI" missing on display ":0.0" ride153 Using Fedora 9 18th April 2005 02:10 PM
Current GMT-time: 04:19 (Friday, 24-05-2013)
